Discussion topic: Ethernet connection
Message posted on 22 Nov 2025 08:39 PM
Ethernet connection
Message posted on 22 Nov 2025 08:44 PM
Re: Ethernet connection
@Skillybob On your stream puck open the netflix app, go to Get Help, run connection test, what speed is bein g reported?
Message posted on 22 Nov 2025 08:45 PM - last edited: 22 Nov 2025 08:54 PM
Hi @Skillybob
Unlike other devices ethernet doesn't take precedence. You need to turn WiFi off in the settings of the puck.
Also what speed is your puck receiving? You can check in netflix (profile pic > get help? > Connectivity check). Sky say you need 25Mbps for HD and 30Mbps for UHD.
MikeAlanR
Message posted on 23 Nov 2025 07:07 PM
Thanks, it gives 79.81, so should be plenty for the Sky stream service. I can watch Netflix and BBC player without issues but anything from the TV guide just won't load. I'm seriously unimpressed with this as a service.
Message posted on 23 Nov 2025 07:09 PM
Thanks, I was aware of that and had switched off the WiFi and connected via ethernet in the settings already. We have been watching fine for 2 or 3 months until a few days ago.
