Discussion topic: Delay
This message was authored by: Ceri49
Message posted on 15 Jan 2026 07:07 PM
Delay
The TV is always having a delay in showing programs
Find out more
Message posted on 15 Jan 2026 07:50 PM - last edited: 15 Jan 2026 07:51 PM
Re: Delay
Hi @Ceri49 Have you tried rebooting the Glass TV / Puck? If not try it as it tends to remove any glitches that are building up. Go to Settings > System Maintenance > Resets & Updates > Restart device.
