2
This discussion topic has been answered Discussion topic: Controlling volume on sky stream
This message was authored by: Jonathan85
Hi we just got in to sky stream with help from sky but now the volume control doesn't work after it was set up cant access the settings on screen
This message was authored by: JimmyD Answer
Re: Controlling volume on sky stream
Does the power button still work for the TV?
If you go into the settings options at the bottom of the homepage, then connected devices and select the remote, from there you'll be able to reprogramme it to your TV.
Hope this helps.
Hope this helps.
Avatar for Jonathan85
Level 3 icon
It's sorted 👍
