Discussion topic: Constant problems
This message was authored by: IW68
Message posted on 05 Jun 2025 08:54 PM
Constant problems
I am fed up with my sky either losing connection or lately sound going off halfway through a programme. I have done a reset and it still does nothing so I have to switch back to normal TV.
This message was authored by: Stephen+Mourton
Message posted on 05 Jun 2025 10:18 PM
Re: Constant problems
@IW68 If your router and puck are not connected via an Ethernet cable, do they have a clear line of sight to each other? Are they both clear of objects near them especially if your router is by a window or mirror as these can cause the problems you are having.
