Discussion topic: Connection issues
This message was authored by: Bobbingalong
Connection issues
Hello all...newbie here. Decided to go for sky stream so got the puck and modem last week and the broadband went live today. I have connected the cable from the fibre box into the modem but am unsure how to connect the modem to the puck. Help appreciated. Thanks
This message was authored by: Padam_Padam
Re: Connection issues
You can connect to your router either via WiFi or ethernet cable.
Connect the puck to your TV via HDMI, turn both devices on, select the HDMI input using your TV remote and follow the on screen instructions.
Avatar for Bobbingalong
Thanks for rapid reply ! Which socket on the modem do I use ?
Thanks again.
Thanks again.
You can use any ethernet port on the router.
Thanks.....will give that a go.......now.
Nothing doing...the screen is telling me I have a connection issue !!!!!
Modem sat there with white light on.  Puck has power light on
Cable in to modem straight from the box.  Ethernet cable from router to puck.
What type of broadband do you have? Is it from Sky? Is it full fibre? Was it installed by Sky/Openreach? What type of router do you have?
You may want to have a read of this page if you have full fibre from Sky:
https://www.sky.com/help/articles/optical-network-terminal
Sky hub 86a.  SR23 02 UK Full fibre. Installed by openreach, activated by sky
Are all your other devices connecting to the Sky broadband? Is the router generating a WiFi signal?
Screen now says no wifi ?
Are other devices connecting to the WiFi generated by the router? A mobile phone? A tablet/iPad?
If not, try rebooting the router and make sure all the lights are lit on the front.
Only one light on the front...white.
This message was authored by: Jporch316
Try and reboot your router
if that fails it sounds like your internet is not activated
How many lights should be on when allis ok ?
Three. Power, Internet & WiFi.
