Discussion topic: Connection issues
This message was authored by: Jay2509
Message posted on 07 Mar 2024 06:26 PM
Connection issues
Just set up new Puck. Says updating software for the last 29 minutes with 0% progress
Find out more
Message posted on 07 Mar 2024 06:57 PM
Re: Connection issues
@Jay2509 This is quite common. Unplug the puck for a couple of minutes and then plug it in again and start the setup process again.
