5
This discussion topic has been answered Discussion topic: Channel Listing for Sky Stream
This message was authored by: JMCG1
Does anyone know if you can watch 'regular' tv, BBC1 etc on Sky Stream in a similar way that you would on Sky Q? No channel listing is available for Sky Stream so I'm wondering if it is just a streaming service similar to NowTV
This message was authored by: Padam_Padam Answer
Re: Channel Listing for Sky Stream
The channels available on Stream are listed here, although confusingly (common with Sky) they call it Sky Ultimate TV on here, yet it's known as Entertainment when you order it...
https://www.sky.com/help/articles/tv-channel-list-sky-glass
Channel listings are available for both Sky Stream and NOWTV for the channels available, both are streaming services and there is nothing to prevent streaming services having channel listings😉
@JMCG1
On Q, all 'regular' television arrives over the satellite dish.
On Stream it's delivered online.
The coaxial cable connector and DTTV tuner in a Stream puck is there for regulatory compliance in other territories (such as Italy).
That would be due to a fault or the lack of a Stream subscription.  Stream has zero non-subscription functionality (which is also the case with Q)
This message was authored by: Bill051
Either press "home" on the remote and then select "TV guide" OR press the microphone button and say "TV guide".
Sky Broadband, Sky Stream via ethernet
Amazon Firestick
Previously VM
Answered - Go to Answer
