12 Feb 2024 12:59 PM
Is there a way to change between HDMI inputs with the sky stream remote.
12 Feb 2024 01:17 PM - last edited: 12 Feb 2024 01:19 PM
Not direct from Sky Glass/Stream Remote
You do the following instead
Sky Glass
Home Menu screen
Apps and Inputs
You can then select HDMI 1 or 2 or 3
When using Sky Stream
Use your TV remote instead as that will have a button for changing HDMI inputs
12 Feb 2024 01:19 PM - last edited: 12 Feb 2024 01:20 PM
There's no dedicated button on a Stream/Glass remote for input change: Sky appears to have left this out because of incompatibility issues with previous Sky remotes and some television make/models.
29 Jul 2024 05:39 PM
A basic thing like this being missing defeats the purpose of being able to control your TV with the Puck control. A customer thumbs down from me ....or is it deliberate to make you just watch sky more ...mmmm I wonder ?
29 Jul 2024 05:46 PM - last edited: 29 Jul 2024 05:47 PM
That's never possible for more than basic control anyway: a puck remote cannot get to television settings or on-TV apps, as is typically the case for handsets other than the one which ships with the television set.
