11
Discussion topic: Changing from Sky + to Sky stream
This message was authored by etonmess This message was authored by: etonmess
Hi
I want to change from Sky+HD to Sky stream. I have 2 boxes that feed 2 separate TV's each on them. I cannot see any account to subscribe to as it only gives me Sky glass. Has anyone ant ideas. Have phoned but cannot get the operators to understand what I want.
This message was authored by bob1234 This message was authored by: bob1234 Answer
Re: Changing from Sky + to Sky stream
@etonmessGo to "Sky.com" and use the TV drop down at the top and then "stream" is an option.
@etonmess  Unfortunately you need to call Sky to go from Sky +HD/Sky Q to stream, before you do that you need to be aware that stream is broadband only and needs a good speed for each puck, around 25 mbps for the 1st puck and 10mbps for the second puck.
You also need to be aware stream is a different system from Sky + and that it doesn't record to a hard drive.  Some channels are missing from stream see this list to ensure the channel you watch are on there https://www.sky.com/help/articles/tv-channel-list-sky-glass
This message was authored by Mark39 This message was authored by: Mark39
@etonmess wrote:
Hi
You can't use your existing coax/magic eye (I assume) setup to directly distribute picture and sound from a Stream box to two different TVs. Sky Stream boxes have no RF output. The simplest solution would be to rent a separate Sky Stream box for each of the 4 TVs. To subscribe you would need to call.
Do be sure to understand the bandwidth requirements as @GD1 posted and the differences between Sky Stream and Sky+.
This message was authored by Rouffian This message was authored by: Rouffian
@bob1234This isn't helpful, as what will happen is that you will either not see Stream if you log in immediately, or when you do the option will be removed and you are offered Glass instead.
I have a similar issue and my guess is that I will need to buy Stream with another email address, and then cancel my existing contract, then change my new 'fake' email address back to my main one.
This message was authored by best+of+the+best This message was authored by: best+of+the+best
@Rouffian you need to ring Sky why do you feel the need to use a fake email address you need a registered home address for the Stream to be delivered too.
Plus you are still in contract so again you need to ring Sky.
Thanks, @best+of+the+best .
I guess ring Sky then.
I don't suppose anyone knows the number? I can't find it.
This message was authored by Hartleys1964 This message was authored by: Hartleys1964
Morning. I am just in the process of changing from Sky+ to Sky stream. Does anyone know if I will still be able to access the programmes currently on my Sky + planner and if i will still be able to view the movies that I have reatined which I have paid from from sky store
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Anything recorded on your Sky + won't be retained as they are stored locally on the box's hard drive. There is a good chance most of that content is available via the various catch up services that are available on Sky Stream (dependent on your having a subscription to the various catch up services).
Purchases on Sky Store are retained. There is a Sky store app on Sky Atreak that you login to and from where you can then stream your Sky store library.
Sky Stream and Sky Broadband customer
Thank you so much for letting me know. I really appreciate it
No worries - I actually made the same switch 1 year ago this month. Personally i've got no major issues with Stream and actually prefer it over Sky +, however it is a completely different UI and way of working. If you use streaming services like IPlayer or Netflix or Disney etc quite often then i think the jump over to Stream is relatively simple and straightforward as it works just like a streaming service and has a UI design similar to other streaming services.
