Discussion topic: Can’t turn on puck with remote
This message was authored by: THC
The puck won't turn on with remote. The remote fully functions once I've turned puck on manually and will switch it off but it won't switch it on
Re: Can’t turn on puck with remote
This message was authored by: Stephen+Mourton
@THC   That is strange.  The only thing I can think of is (if you haven't already) unplug the puck from the power source leave it a minute or so and plug back in.  I hope that sorts it, if not I'm sure someone on here can help.
Avatar for THC
Thanks I've done that and I've unpaired and repaired but it's still the same
This message was authored by: darling412001
It takes a long time (5 seconds) for mine to turn on but it gets there eventually. I press the Home key by the way.
Sky Stream
OS 1.3
Build QS040.040.00P
UI 3.268.3
Platform 8.4p40s1
Hardware IP061-ef
TV Sony A95K
AV Sony HT-A9
Broadband Hyperoptic FTTP 1.0Gbps
Ethernet to Sky Stream
This message was authored by: Jporch316
@THC
I have escalated your post to the online sky community support team. Please lookout ofr a bubble icon indicating an invitation to chat with them
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @THC.
