Discussion topic: Buttons on my sky remote (sky stream) have stopped working
This message was authored by Rhw1967 This message was authored by: Rhw1967
All of a sudden most of the buttons on my sky remote have stopped working.
It will turn on and off, and that is all. None of the other buttons work except strangely the left part of the wheel turns off sky tv too.
I have changed batteries, I have down the whole reset and reconnect the remote about 10'times!!! Still nothing.
Can someone please help ? I've tried calling sky and given up having been on hold for over 30 mins (I work long hours and this call on hold used up my break)
This message was authored by Greenfingers001 This message was authored by: Greenfingers001
Re: Buttons on my sky remote (sky stream) have stopped working
Posted by a Sky employee
Hi there @Rhw1967 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Rhw1967To help you try to get your remote working the links below are to remote troubleshooting guides:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine).
If none of the above works then phone Sky to discuss and request a replacement remote.
If you have one available you can use a Sky Q remote.
If my post has solved your issue please mark as an "Answer"
Rhw1967
Thanks guys... I have literally tried everything recommended by sky and the community, no luck and very frustrating .. I do appreciate your help
This message was authored by Addie15 This message was authored by: Addie15
Update-We are closing this session now but if there is anything else in the future we can help you with, please do not hesitate to reach out. Thanks.
This message was authored by May66 This message was authored by: May66
My remote isn't working I've changed the batterys and it's not working
