Discussion topic: Broken power cable
This message was authored by: Bandit4
Broken power cable
Hi there, my sons rabbit bit through the power cables of his sky puck, so you know what the cable is called and can you order them from sky
Re: Broken power cable
@Bandit4  Your post has been moved from the Sky Q Board as you state it's a puck?
In any case you will need to call Sky and they will replace the puck as they don't send out power cables.
Someone may be able to provide some information on that but these are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
This message was authored by: HA05GER
I like your setup I have fttc with a 4g back up via three. All three of my puck actually permanently run on the 4g. I hate paying for the backup and not using it.
