2
This discussion topic has been answered Discussion topic: Broadband Speed
This message was authored by: Dragonlady
Broadband Speed
What is the minimum Broadband speed required to operate Sky Stream.
This message was authored by: Nigelb1972 Answer
Re: Broadband Speed
25mbps for HD and 35mbps for UHD are the minimum requirements but you really want double this
Re: Broadband Speed
Re: Broadband Speed
@Dragonlady the minimum speeds recommended by Sky are as follows
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
