11
This discussion topic has been answered Discussion topic: Audio on cbeebies not working
This message was authored by: Dean1988
The audio on cbeebies is not working. I have checked the other channels and they are working just not on the cbeebies. Is there a specific issue?
This message was authored by: lettice Answer
Re: Audio on cbeebies not working
The sound on this channel has been fixed now.
If anyone is not hearing it, try a settings restart of your Sky Stream/Glass Tv.
This message was authored by: Dan199522
No audio on CBeebies
audio works everywhere but on CBeebies? Have completed all the standard "fix its" but there's still silence
Re: No audio on CBeebies
Open the iPlayer app and stream CBeebies from there instead.
This message was authored by: Inglesra
No sound ch 202
No sound on ch 202 today for last few hours
Re: No sound ch 202
Just checked, not hearing any sound on that channel.
Would suggest to get this flagged to Sky  is to send an email to the Sky Viewer relations team to report it;
[email protected]
They do respond to emails with any updates for your queries or problems.
Re: No sound ch 202
Thanks. I've written to email so will wait for answer.
This message was authored by: EmEvans
Mine is the same has been since 8 this morning
This message was authored by: SMunro10
Yep same here. No sound on any TV in house with Sky PUK
@Dean1988 @SMunro10 @EmEvans
You can let Sky know via this email address, do let them know this is a Sky Stream issue - [email protected]
This message was authored by: BigDaddyKoolG
I have been having the same issue since 08:45 this morning. The sound has seemed to have returned but the sound is out of sync.
i spoke to a Sky Technical Advisor who said that there had been no reported audio issues at that point and after carrying out diagnostics on my Sky Stream Puck.
So the end result was for the advisor to send me out a new Sky Stream Puck via DPD.
I have restarted my Sky Stream Puck but the audio is still not syncing with the picture.
