Discussion topic: iPad not showing purchases from sky store
Message posted on 13 Jul 2024 11:31 AM
I am Unable to see or download purchased sky store films, only able to watch them when connected to my sky q and they're in my recents. I want to download to my iPad but they aren't available to do so.
Message posted on 13 Jul 2024 11:56 AM
Re: iPad not showing purchases from sky store
Try installing and logging into the Sky Store app as this show allow you to view and watch your purchases.
Message posted on 13 Jul 2024 12:51 PM
I can watch or download only certain shows in my recordings, can't download purchases. And It's saying I've reached my maximum devices even though it's now in my devices.
Message posted on 13 Jul 2024 01:13 PM
Is it the Sky Store app that is returning that message as it isn't clear what you are doing or what app you are using ?
Message posted on 13 Jul 2024 01:17 PM
Sky store app shows all my purchases, but can't download or watch. Sky go connects to sky q but only shows purchases that are in my recent recordings. And will stream through that, but not download. All other purchases are not shown.
Message posted on 13 Jul 2024 01:21 PM
What happens when you select one to watch ?
Message posted on 13 Jul 2024 05:54 PM
Device Limit Reached
You've reached your device limit. You can make 1 more change this month.
To download on this device you need to delete one of your registered devices.
Go to skystore.com/myaccount.
Message posted on 13 Jul 2024 07:34 PM
How many devices do you have the Sky Store app installed on ?
Message posted on 13 Jul 2024 09:21 PM
An X-Box an iPhone and the iPad. I can download onto the phone but not the iPad. I've tried deleting the apps and setting them up again. Only the iPhone and Xbox work. I can't download anything onto the iPad.
Message posted on 13 Jul 2024 10:14 PM
That could be your issue as I *think* you can only add one device per month.
Message posted on 14 Jul 2024 02:56 AM
@Ants+H wrote:Device Limit Reached
Did you log in to Skystore.com and check you device list?
Message posted on 14 Jul 2024 05:58 PM
It's literally in my list, but not working fully!! 🙄🤷♂️🤦🏻♂️
Message posted on 17 Jul 2024 08:12 AM - last edited: 17 Jul 2024 08:19 AM
I had an issue in the past where I had to remove my allocated devices and then add them back over subsequent months🙁
The Sky Store softwares is showing its age and needs a total rewrite ... it is ridiculous how few devices it is available on ... and no general UHD/HDR support across all devices😟
Message posted on 16 Oct 2024 09:18 PM
I had to get in touch with Sky for this one eventually, as there are two places where there's a device list. And I was trying to add my iPad to the wrong list apparently. Sorted anyway, but it's a few months ago now so I can't remember where the two lists are exactly... 🤔🙄🤣
