2
This discussion topic has been answered Discussion topic: Ordered rental on my phone its not showing on sky q box
This message was authored by: Jenny1808
Hi i ordered the Tom and Jerry movie (rental) and it's not showing in my rentals section on the sky q box
This message was authored by: mike+simmonds Answer
Re: Ordered rental on my phone its not showing on sky q box
Hi @Jenny1808
Unfortunately, rentals made on a device can't be sent to your Sky box
Usually with ordinary rentals - there are a few workarounds although I haven't tried them with the Premier Rentals. These do have extra copy protection built in, but you can try the following which usually work
You can cast to your TV if you have a Chromecast or TV with built in Chromecast
If you have a recent LG TV you can download the Skystore app on there
If you have a laptop or PC with HDMI output- you can plug that in to your TV
Hope that helps
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Hi @Jenny1808
Hope that helps
Sky Q 2TB main box
LG CX6LA from 2020
For the film to be viewable via your Sky Q box it needed to be rented via the box itself as rentals can only be watched via the box if they were rented on it because unlike with Buy and Keep they can not be sent to a Sky box.
