2
This discussion topic has been answered Discussion topic: Finding Sky Store purchases on Sky Stream (puck)
This message was authored by: Uffy1
Hi,
I have Sky Stream and have purchased a movie via the Sky Store. It advised that the movie can be found in 'My Library's, however there is no such section on my Sky Stream interface. I can search for the movie manually and play from there but there must be a way to find all my purchases in one section on Sky Stream?
Anyone able to help?
Cheers!
Re: Finding Sky Store purchases on Sky Stream (puck)
Does this help:
https://www.sky.com/help/articles/sky-stream-faqs
To buy, rent or watch any Sky Store purchases, you’ll need to use the Sky Store app (through the Movies > Apps menu) on Sky Stream. Or you can use voice control on your Sky remote. Press and hold the Voice button and say "open Sky Store". Then just log in with your Sky iD details.
Does this help:
Avatar for Uffy1
Thanks @caesarome ! Would be great to see this as a standalone section accessible from the home screen rather than having to open the sky store app and find movies > my library. Any idea how to submit to Sky as a suggestion?
