6
This discussion topic has been answered Discussion topic: 2 for £8 on sky store
This message was authored by: Sujjy
Looking to buy the spiderman films for my son on sky store.
They are currently on offer at 2 films for £8 but when I go onto each film it says £4.99 digital download or £3.49 rent there is no option to buy 2 films for £8 anyone know how you buy 2 for £8??
This message was authored by: mike+simmonds Answer
Re: 2 for £8 on sky store
Hi @Sujjy
I asked the same question recently relating to 2 for £8 buy and keep (rather than rentals)
the system is - you buy one of the movies from Skystore. (Say for £5.99)
the sky system then puts a "credit" on your account so that when you buy the second movie in the offer - it reduces it to £2.01
That has worked fine for others - hope it does for you.
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
This message was authored by: fizzdisco
@Sujjy
Where are you seeing the 2 for £8 offer?
Which Spider-Man movies are you looking for? You can get the first three movies as a box-set for £10.99 on Sky Store at the moment:
https://www.skystore.com/boxset/movies/spider-man-1-3-movie-box-set/f0cbaaa4-99fb-44f5-beca-b4f46aa8...
Hi @Sujjy
Sky Q 2TB main box
LG CX6LA from 2020
Avatar for Sujjy
Thats great thanks 😊
Avatar for Sujjy
@fizzdisco when you go on sky store then go on spiderman no way home if you go down on that it has all the other fils and shows 2 for £8 for all the other films 😊 my son wants to watch them all
Ah, I see. I was looking on the Sky Store website which makes no mention of the 2 for £8 deal!
Avatar for Sujjy
Ah that explains all. Thanks all sorted now  😊
