Discussion topic: viewing in another room
This message was authored by: roger30
I would like to be able to watch sky tv in the bedroom , how can I do this please.
Re: viewing in another room
Hi @roger30   By subscribing to Multiscreen and ordering a Sky Q Mini box at the same time. Note, Multiscreen does not come with a Mini box by default, as people subscribe to it to watch on phones, tablets, etc.
https://www.sky.com/help/articles/watch-sky-in-different-rooms
Avatar for roger30
OK  , thanks for that .
Avatar for roger30
I should mention that I don't have wifi in the home , does multiscreen still work ???
Hi @roger30   As far as Mini boxes are concerned, Multiscreen works using the Sky Q Mesh, not broadband WiFi. So that may be an advantage. How is the Main Sky Q box connected to the internet?
Avatar for roger30
Hello there ,
the main sky q is not connected to the internet as there is no landline or router in the house .
So I'm wondering then if multiscreen will work ?
Thanks ,
@roger30 wrote:
Hello there ,
Thanks ,
hi @roger30
No - even though Minis will connect using a wifi generated by the main box they need a router to issue IP addresses - although it need not be connected to the internet (except see below)
I believe minis also need an internet connection for initial authorisation also
