Discussion topic: updates everyday
Message posted on 10 Apr 2025 09:47 AM
updates everyday
our sky q box will have a cross on the network connection in settings nearly every day of the week and we have to do a software update every day to get back to a tick on the network connection absolute pain in the neck
Message posted on 10 Apr 2025 10:55 AM
Re: updates everyday
@Gary.ingham wrote:our sky q box will have a cross on the network connection in settings nearly every day of the week and we have to do a software update every day to get back to a tick on the network connection absolute pain in the neck
Although the Sky box is implying that you are doing a software update, all you're actually doing is forcing a box restart - the software version will be staying the same.
Message posted on 10 Apr 2025 10:58 AM
Hi @Gary.ingham
It's pointless doing a Software update if it is already on the latest software.
Sky Q Software version for all Sky Q box types: Q300.000.06.00L
If it doesn’t match this version number, go to update your Sky box software.
If your Q box software is up to date try the following.
If you are on Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button. If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 11 Apr 2025 10:12 PM
Has your box updated to software version Q300? My Q refuses to say it's connected to the internet since the update. However, briefly on my minibox I got into Netflix even though it said there was no internet. As soon as I came out of netflix it reverted to refusing to allow any on demand content.
