Discussion topic: Unable to watch recording of F1 on mini box
This message was authored by: EXC
Sky last weekend showed the formula 1 race live on two different channels. Both were broadcast in UHD. I recorded one of them and then tried watching the recording via the sky Q mini box. I received a message to say the recording was not compatible with this box.
This then caused problems in my household as I had to disrupt the family to watch it on the main sky Q box. This is going to be a problem throughout the season.
I do not understand why Sky broadcasts both channels in UHD if that format is not compatible with the appliances they provide and we pay for. Or have I missed a setting somewhere in my mini box?
thanks
Re: Unable to watch recording of F1 on mini box
Nope: Mini boxes do not have the video chipset or HDMI standard required for UHD output, and a main Q box can neither rebroadcast UHD or downscale it to HD for Mini box use.
@EXC Mini boxes can't display UHD recordings. You would need to record the HD channel.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
@EXC
Mini boxes are not UHD compatible. I watched it in HD on the normal F1 channel with no problem. If you record in UHD you'll have to watch it back on the main box.
You'd need to record the HD version to watch on the mini box, I think it's channel 857.
@EXC
Previous posts suggest many F1 fans record both the HD and UHD channel simultaneously to have maximum flexibility on viewing devices later.
Avatar for EXC
Ok thanks everyone for the answers. I will have to look harder for the channel showing it in HD.
I could only see it on two channels and both were in UHD
HD version should be on 857 now that 406 is a dedicated UHD channel
BTW as @TimmyBGood says I record in both formats in case I want to catch up on my mini (although Idon;t do hat very often)
Having been spoiled by the UHD picture quality, I can't bring myself to watch it in HD. Might as well just look up the result 😆
This message was authored by: Scruffer04
Or set F1 to record via the mini box where F1 HD remains at 406.
This message was authored by: derekellis6693
Can't find this channel
Which channel? F1 HD?
