Discussion topic: skye q mini box not loading disney plus
Message posted on 03 Nov 2023 09:05 PM
I have a main q box and 2 mini boxes. Both of the mini boxes won't play anything on Disney plus. Disney plus opens and loads, I can see all the available shows, but when I press play the screen goes dark and a wheel in the middle of the page just spins.. Nothing happens. Other apps, Netflix etc all work OK. Other boxes all work OK. I have updated the software on all boxes, disconnected and reconnected everything. Refreshed the apps..
What else can I do?
Message posted on 03 Nov 2023 09:07 PM
Re: skye q mini box not loading disney plus
What else can I do?
Hi @sky2007
Message posted on 03 Nov 2023 09:33 PM
it is still not working
Message posted on 03 Nov 2023 10:17 PM - last edited: 03 Nov 2023 10:18 PM
Hi @sky2007
First thing to check is that both main Q box and all minis are on the same software version. Check in Settings - System info
I know that you have said you have updated all boxes but are they all on the same version?
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version
Message posted on 03 Nov 2023 10:33 PM
still won't load anything on disney plus from the mini box despite doing all the steps you have provided
Message posted on 05 Jun 2024 06:54 PM
I'm having the same issue and sky were unable to resolve over the phone, in fact they just thanked me for letting them know of the issue. Did you ever get a resultion?
