Discussion topic: skyQBox and mini box
This message was authored by: Kat107
Hi why dose my skyq box and my mini box keeps disconnecting from my WiFi and now it can't find my WiFi Wen I'm trying to reconnect why dose this keep happening
Re: skyQBox and mini box
Hi @Kat107
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
