Discussion topic: sky remote not working
Message posted on 13 Nov 2024 10:55 PM
First vol Me on remote didn't work and now nothing works . Have tried resetting by pressing 7 and 9 together .. only flashes twice and then 1 and 3 .. but don't get any screen to reset he controls . So frustrating !! Can anyone help please ??
Message posted on 14 Nov 2024 06:00 AM
Re: sky remote not working
@Hagerstown
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (there is the possibility this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
