3
This discussion topic has been answered Discussion topic: sky q not working
This message was authored by: moosy1
sky q not working
My Sky Q main box is showing "Updating software. Step 2 of 2"  please do not switch off your sky box during this and it has been showing this for over 24 hours.  The Broadband connection is working, it appears to be stuck on this update, I have swiched the box off at the mains and put back again several times and it is still showing the same message.  I would appreciate any assistance. with this problrm.
Re: sky q not working
Hi @moosy1
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Hi @moosy1   Have a look at this Article and it should lead you to replacing your box if required.
Hi @moosy1
Avatar for moosy1
thanks
thanks for replies to previous post re sky q box, which has now neen replaced
