Discussion topic: sky q mini box connection
Message posted on 28 Mar 2024 10:20 AM
recently moved house and have sky q box and mini box. Every time the mini box is turned off i need to reconnect it all to the wifi etc. Any advice?
Message posted on 28 Mar 2024 04:12 PM
Re: sky q mini box connection
Hi @garysmith88
Assume it's Standby that you are putting the Mini into and not turning it off at the mainQ plug?
Try completely resetting the mini.
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
If the mini still does not connect reliably
try a Network Reset on the mini.
