Discussion topic: Hi i have 3 multiboxes 2 of which arnt working, just red light then orange
This message was authored by: Jackie78
Message posted on 28 Mar 2024 03:43 PM
Hi I have 3 multiboxes 2 of which aren't workung
Find out more
Message posted on 28 Mar 2024 04:07 PM
Re: Hi i have 3 multiboxes 2 of which arnt working, just red light then orange
Hi @Jackie78
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair with TV.
