Discussion topic: sky q box freezing
This message was authored by: StevenThomas65
sky q box freezing
Our sky Q main box keeps freezing and then turning itself off.
Re: sky q box freezing
Hi @StevenThomas65
Try a Reset Settings in the main Q box hidden menu.
