This discussion topic has been answered Discussion topic: sky q and mini box
Message posted on 10 Apr 2023 01:54 PM
is it woth changing over, at the moment i have basic sky box and and sky eye to watch tv in another room.
I have it on order to come soon, but now wondering if its worth it
Message posted on 12 Apr 2023 03:28 PM - last edited: 12 Apr 2023 03:29 PM
Sky won't know you were using a 'magic eye' previously. However, if you specifically ordered a Mini box (or took the 'VIP Upgrade' which includes one) then the installer will bring it, together with the main Q box, and attach it to a second television.
Message posted on 10 Apr 2023 02:43 PM
Re: sky q and mini box
@saddy1 wrote:is it woth changing over, at the moment i have basic sky box and and sky eye to watch tv in another room.
@saddy1 Only you can judge whether it's worth it from a financial standpoint. You will gain the ability to watch two different things on your two TV's at the same time and the second TV will be in HD.
The user interface is quite different though, so might take some getting used to. Also, a couple of things that you might currently use on Sky+ (Bookmarks and Reminders) aren't available on Sky Q.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 12 Apr 2023 02:24 PM
Will they put the mini box upstairs, if the sky q is downstairs?
Message posted on 12 Apr 2023 02:56 PM
If you've ordered Multiscreen and a Q Mini box, then yes. The main Q box goes on the end of the dish cabling: you can choose to have this relocated if you wish. The Mini box typically connects wirelessly to the main box.
Message posted on 12 Apr 2023 03:20 PM
All I was told was I have a sky q box? And mini box.?
Message posted on 12 Apr 2023 05:08 PM
Very helpful thank you
