Discussion topic: sky multi room
This message was authored by: confused91
sky multi room
I have sky Q. I would like to have multi room but I believe the mini box doesn't record or play ultra HD. I want ultra HD in a room the opposite side of the house to the dish. I am  willing to forego UHD on the current TV which is connected to the sky dish. Is this possible?
Re: sky multi room
Not easily.
UHD will only work on the main box and needs satellite feeds to do this.
Sky stream can do it but is quite a different product.
Avatar for confused91
Re: sky multi room
thank you for the information
