9
This discussion topic has been answered Discussion topic: sky mini far from main box
This message was authored by: Evsie88
I'm putting a tv in garage which a way from my main sky box in garage. I have a Ethernet cable in but how will I connect my mini box to the main box if they far apart...
This message was authored by: nigea99 Answer
Re: sky mini far from main box
@Evsie88 wrote:
What if I can not connect my main Q box to Ethernet? It's on Wi-Fi in house. @Chodley
hi @Evsie88
When your provider is not SKY then the minis connect to the main box via a wifi signal generated by the Main box - which as you say is too far in this case - or must both be connected via ethernet either to each other or both via an ethernet connection to the same network
(BTW  boosters/extenders sometimes are not suitable for this connection as I think they can be  treated as a different part of the network - but I am not an expert in this area)
Thus I am afraid if your main box is not connected to via ethernet to the same network as the mini via ethernet then it won't work
hi @Evsie88
Who is your broadband supplier and to what is your Ethernet connected?
Avatar for Evsie88
It's Virgin... Ethernet is outside in garage connected to Wi-Fi booster for PlayStation etc
Hi @Evsie88
Afraid the mini will not work with that Ethernet.
Put a switch in the garage. Connect the wifi booster and the mini to it.
Connect the Q to the router by ethernet as well. I assume the Q isn't also in the garage, contrary to your opening post?
Then they will find each other.
Avatar for Evsie88
hi @Evsie88
Avatar for Evsie88
@nigea99 @Thanks so much.
do you know if I am able to play sky go via my iPad or phone and cast to the tv instead then? Doesn't seem like that's available to me or am I missing it 🙂
I am afraid I don't think you can cast from a tablet or phone but could possibly use a laptop with an HDMI output or a games console that supports SKY Go (At least one of the SU's uses their playstation connected to a TV)
Ethernet can go 100m
Or use powerline
or use ethernet into a wifi mesh node which is connected to the rest of your network.
