Discussion topic: sky mini connected but displaying technical fault
Message posted on 09 May 2024 04:14 PM
All 3 sky mini boxes connected but displaying technical fault. i have triedmany different reset a new main box but still displaying fault
Message posted on 09 May 2024 06:13 PM
Re: sky mini connected but displaying technical fault
Try the following.
When the main Q box is back up and running reboot a mini. Start with the one nearest to the main Q box or the Router if on SKy broadband.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
As soon as the mini is back up running try a Network Reset on the mini.
If on Sky broadband and the router is nearer to the mini on the main try WPS on the Sky router,
Carry out the same procedure on you other minis. If a connected mini is the neares Q drgice then use WPS on that when carrying out the Network reset.
Message posted on 07 Jun 2024 07:29 PM
thanks but none of the above has worked. very annoying!!
