Discussion topic: sky dish is damaged
This message was authored by: francis2
sky dish is damaged
my sky dish outside my house is damaged and will need fixed asap as iv no tv at all. it says on my tv. this channel is currently affiliated with your satellite signal. just checked my dish and it's damaged
Re: sky dish is damaged
@francis2
You will have to call Sky and arrange an engineer. Sky may charge you as you own the dish.
Avatar for francis2
It says its free as I didn't break it but they can't come out untill 2nd October? Is there anything else I can do?
@francis2
Arrange a local satellite company to repair/replace but that won't be free.
Avatar for francis2
Will do, thanks 😊
If you need it 'asap' then you will likely have to pay a local firm to fix it.  Otherwise, call Sky and see when an engineer is next available (it may be days or weeks).
Usually, they will consider a credit once fixed (from when reported).
This message was authored by: Frederic
Re: sky dish is damaged.
The satellite dish got damaged and there is no signal at all. The receiver got knocked down. Can I get someone in ASAP or would a replacement from the shop work.
@Frederic
Like the responses to the original post you'll need to call Sky and book an engineer. Depending on the damage there may be a charge.
As above, it will depend on engineer availability- could be days or weeks.  You may wish to consider paying a local contractor if it's not quick enough.
