Discussion topic: sky box not working
This message was authored by: chloe_x
sky box not working
it's stuck on a page of "accessibility on sky Q"
it's got a setting option or "skip and set up later option"
if won't let us pick either one however the remote does work.
Re: sky box not working
hi @chloe_x
Reset your Q box remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box.
Switch your Q box back on and you then you should be able to get past the setup issues.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
