Discussion topic: sky Q
Message posted on 10 Jul 2023 11:12 AM
sky Q
I am trying to access signal strength on my sky q system. info says press services on sky q remote control and press 4,6 . but which is sky services button? all help to someone having a bad Monday will be gratefully recieved.
Message posted on 10 Jul 2023 11:16 AM - last edited: 10 Jul 2023 11:18 AM
Re: sky Q
There is no 'Services' button on a Sky Q remote: that would be for Sky+
On Q a figure for signal strength is found in the 'Settings' menu under 'Status'
Message posted on 10 Jul 2023 11:18 AM - last edited: 10 Jul 2023 11:22 AM
Re: sky Q
hi @CBBT
I suspect that is for a different system.
The signal strength is shown :
Home - Settings - Status - Satellite Signal - Scroll right & Select More Info
However please note on SKY Q it does not show the status of the current channel but instead a fixed transponder set in an engineers panel - so it can say all OK but the channel you want to watch may be slightly out
Message posted on 10 Jul 2023 11:18 AM - last edited: 10 Jul 2023 11:19 AM
Re: sky Q
Hi @CBBT
.Are you sure that you on Sky Q?
Services menu is on Sky+ HD and not on Q .
An indicative Signal Strength and Quality is found in Q Home menu.
Home - Settings - Status..
Scroll right to Satellite Signal - More info.
Message posted on 10 Jul 2023 11:39 AM
Re: sky Q
Thank you all, I thought it was on sky+hd, but on the info panel on sky.com it does say this is how you find services on sky q.
Anyway thank you all for the responces !
