Discussion topic: sky Q not working - Not programmed
This message was authored by: jmckie1
unable to access sky - says Not Programmed
Re: sky Q not working - Not programmed
@jmckie1 wrote:
says Not Programmed
@jmckie1
Are you sure that's not a message from your TV?
@jmckie1
(As my signature at the bottom of my post states I don't offer help via PM). As stated this is probably a message from your TV. Doing a search at the top of the Sky Q board and inserting 'not programmed' provides quite a few similar posts where the same advice has been given. Not programmed is a message from your TV's Freeview Tuner.
