Discussion topic: sky Q box main
This message was authored by Nicole7 This message was authored by: Nicole7
sky Q box main
Turned on my Sky Q box tonight and there is no lights on front panel, there is nothing whatsoever, can anyone help me with this problem. Please
This message was authored by Chodley This message was authored by: Chodley
Re: sky Q box main
Have you tried pulling the power?
does it have an external power brick?
Nicole7
Re: sky Q box main
Yes I pulled the plug out and put it into another socket and still nothing.
Nicole7
Re: sky Q box main
sorry I don't know what an external power brick is?
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: sky Q box main
Is the power lead plugged straight into a power socket or is there an adaptor box in the middle?
If it's dead (checked the fuse and socket?) then you'll need to call Sky for a replacement box.  (Remember to remove your viewing card)
I am just another Sky customer and my views are my own
Re: sky Q box main
You haven't got one then. V2 Q boxes have them. V1 and v3 do not, they have internal power supplies. Suspect easier to fix/swap without losing your box and therefore recordings if that is what has failed, which your symptoms suggest may have happened.
