Discussion topic: sky Q box main
This message was authored by: Nicole7
sky Q box main
Turned on my Sky Q box tonight and there is no lights on front panel, there is nothing whatsoever, can anyone help me with this problem. Please
Re: sky Q box main
Have you tried pulling the power?
does it have an external power brick?
Avatar for Nicole7
Re: sky Q box main
Yes I pulled the plug out and put it into another socket and still nothing.
Avatar for Nicole7
Re: sky Q box main
sorry I don't know what an external power brick is?
Re: sky Q box main
Is the power lead plugged straight into a power socket or is there an adaptor box in the middle?
If it's dead (checked the fuse and socket?) then you'll need to call Sky for a replacement box.  (Remember to remove your viewing card)
Re: sky Q box main
You haven't got one then. V2 Q boxes have them. V1 and v3 do not, they have internal power supplies. Suspect easier to fix/swap without losing your box and therefore recordings if that is what has failed, which your symptoms suggest may have happened.
