Discussion topic: sky Q Error MR106
Message posted on 03 Dec 2024 10:21 PM
sky Q Error MR106
Hi my Sky Q Box has a MR106 error I have tried to reset by unplugging both box and resetting my router
Message posted on 03 Dec 2024 10:26 PM
Re: sky Q Error MR106
Hi @TC31
You need to carry out a Network Reset found in Q box Home - Settings - Setup - Network.
