Discussion topic: setting up a new sky q mini box
Message posted on 20 Mar 2025 09:16 AM
setting up a new sky q mini box, It's stuck on step 3 which is 'Obtaining IP address
Message posted on 20 Mar 2025 10:44 AM
Re: setting up a new sky q mini box
Hi @DanielHa
Reboot the mini as above.
