Discussion topic: relocating sky box
This message was authored by: Ginalh
relocating sky box
I would like my sky box reloacting to a different part of the room
Re: relocating sky box
You can either purchase extension cables (if required) or you'll need to contact Sky for them to reroute the cables externally (if possible) - there will be a charge for that.
This message was authored by: Donwoollwy7
Can you please let me know how much it will cost to relocate my Q box to the other side of the room
@Donwoollwy7 you can buy extension cables that you can do yourself or if you want a Sky engineer they currently cost £65 see here  for extension cables other suppliers are available 😀
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
