This discussion topic has been answered Discussion topic: recordings not showing and downloads not working
Message posted on 02 Jun 2023 09:12 PM
No recordings are showing in the recordings section. I can't record, view recordings or delete recordings, nor can i download any programmes. When I try to download I get an error message that reads "Because of a technical issue your download can't be completed. Please try again later"
I have rebooted my box. Twice. It didn't work
I have tried navigating to Settings, not pressing settings but instead typing 001 but that does not bring up an engineers menu (or anything else) so I can't reset my hard drive.
What should I do
Message posted on 02 Jun 2023 09:28 PM
What should I do
Hi @JayMo369
You have to press select after 0 0 1
What should I do
Hi @JayMo369
Message posted on 03 Jun 2023 08:56 PM
Re: recordings not showing and downloads not working
thanks @oldfella - that worked
Message posted on 26 Jun 2023 07:17 PM
Hi guys what do you do when you get to this hidden menu?
Message posted on 26 Jun 2023 07:20 PM
Hi @oldfella ive got the same problem but unsure what I'm suppose to do when I've got into the secret menu?
Message posted on 26 Jun 2023 07:22 PM
Hi @D.Pitty
Message posted on 26 Jun 2023 07:27 PM
Great @oldfella I will give that a try 👍
Message posted on 26 Jun 2023 07:35 PM
@oldfella didnt work I'm afraid 😬 still no recordings.... not able to use on demand and box doesn't show channels upstairs.
think I'll have to speak to sky and wait on hold for a eternity 😩
