Discussion topic: Ethernet cable
This message was authored by: Johnnyboy-50
Ethernet cable
Hi about to hard wire my sky boxes due to wifi problems but not sure which Ethernet cable I need. Shielded / not shielded etc.
Re: Ethernet cable
hi @Johnnyboy-50
Provided it's all internal,   fully wired  cat 5 or cat 6 would be suitable.
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.
(Switching off WiFi is not strictly necessary if you're on Sky Broadband)
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
