3
This discussion topic has been answered Discussion topic: recordings help
This message was authored by: Cynon
recordings help
i need an easy way to get to recordings as my mum with macular degeneration, arthritic hands and early stage dementia is in tears because she can't work the remote which is too small and too complicated.
This message was authored by: MightyQuinn Answer
Re: recordings help
Re: recordings help
@Cynon if you press the sky logo at the top of the remote (this is a button) it takes straight into recordings
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: recordings help
The voice feature allows direct access to "recordings" too
Re: recordings help
Hi @Cynon   I don't know if an accessibility remote will help https://www.sky.com/help/articles/accessibility-remotes.
Answered - Go to Answer
