5
This discussion topic has been answered Discussion topic: paramount plus unable to use subtitles
This message was authored by: steedie1
I watch paramount plus through my SkyQ . I would like to put on subtitles whilst watching paramount. I can get the subtitles icon up on my screen it has a blue tick with 'off' but no matter what I do I cannot change it, I have tried moving left or right or the middle button but it doesn't change.
I have rebooted the sky Q as previously suggested but it didn't help.
Any thoughts on how I can change the subtitles please.
Thank you
This message was authored by: nigea99 Answer
Re: paramount plus unable to use subtitles
Thank you
hi @steedie1
I have just tried setting on Halo as an example - for me the option is an up/down to highlight  (American/English in this case from off) & then middle button select
Thank you
hi @steedie1
Avatar for steedie1
Level 2 icon
Thanks will give it a try although I am sure I tried that .
Avatar for steedie1
Level 2 icon
Ok, just tried it and it Works!! i hadn't pressed the right buttons. Thank you
This message was authored by: mullionboy
I still can't get the subtitles on--I've tried pressing every button whilst on the subtitles box--up/down/left/right/enter--none of them work
This message was authored by: Jet25
Forgive my ignorance - what is Halo?
