Discussion topic: Sky Q box not working intenet has dropped
This message was authored by Kath461 This message was authored by: Kath461
The Internet dropped last night now tonight we have no Q connectivity with one box, the main one elworks and Internet is dropping out.
Re: Sky Q box not working intenet has dropped
Hi @Kath461
