Discussion topic: no signal sign when switched on have to turn off at mains and switch on again
This message was authored by: whitepines1
The Q box has amber light on it but won't change unless switched off at wall.
Says No Signal.
Re: no signal sign when switched on have to turn off at mains and switch on again
@whitepines1
If a message is displaying ”No signal” it tends to be from your TV (in which case check the HDMI cable between the Sky Q box and your TV).
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
▪️I AM NOT A SKY EMPLOYEE ▪️
Says No Signal.
Hi @whitepines1
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for whitepines1
Thanks for tips still not working without switching off at wall.
Strange thing is that once running it is ok until next day when it won't start again.
My thought is that q box is faulty as when it is cold it won't start up is that possible?
