Discussion topic: no satellite signal
Message posted on 22 Feb 2024 02:25 PM
no satellite signal
sky saying no satellite signal
Message posted on 22 Feb 2024 02:32 PM
Re: no satellite signal
@kimh1981 So what steps have you tried? Anything? https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...
Message posted on 22 Feb 2024 02:38 PM
@kimh1981
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
