Discussion topic: my remote
Message posted on 23 Jul 2026 06:53 PM
my remote
my remote will not turn my ntelevision off and also will not alter the sound
Message posted on 23 Jul 2026 07:38 PM
Re: my remote
Looks like it is not correctly paired to your television @paulineshaw
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair to your television
Message posted on 24 Jul 2026 06:48 AM
Re: my remote
@paulineshaw wrote:my remote will not turn my ntelevision off and also will not alter the sound
You may need to select a different option when selecting your TV from the list, what make & model of TV is it?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
