Discussion topic: multi room mini frozen
Message posted on 26 Jun 2023 10:03 AM
I have multi room, the mini in the other room does not respond after reboot - it has been more that 10 mins
Message posted on 26 Jun 2023 10:18 AM
Re: multi room mini frozen
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 26 Jun 2023 10:35 AM
My Mini box is unusable as it freezes every time I start it. It needs resetting every time I turn it on and within 5 minutes it crashes, screen goes a pink colour and remote doesn't do anything. Back to power off and back on and same thing. Sky have replaced the box and still same thing. Sky engineers don't know what the problem is. Doesn't help that my 2023 iMac isn't compatible with Sky Go either so I can't watch TV on that either. Not good, Sky.
Message posted on 26 Jun 2023 10:45 AM
control now working - thanks- but cannot connect to booster
